94 Z28 drivers electric seat rocking
the seat on the 1994 Z28 im picking up slightly rocks, by this i mean if i lean back the whole seat/top half of the track lifts a little, not much but enoough to be annoying, any suggestions on where to start with this
RE: 94 Z28 drivers electric seat rocking
Had the same problem. The track that the seat rides on is worn out. My fix? I stuck a solid metal rod in there to keep the tracks straight. Greased it up so it would slide with the seat when it was adjusted. Haha! Yea it was rigged but it work and to this day (8 years later) it's still working.
also wondering, how hard would it be to change out the rails, i know of a few salvage yards that i might be able to pull the part from cheap, can i just replace the rail or the whole seat?
It's not hard at all to change the rails. There's 4 bolts that hold the rails to the floor. Same thing happened to my drivers side, bought a used set and installed them in 30 min. One of the easiest swapsI ever did. Remember, the seat slides back and forth for access to the bolts. Took me about 10 min to realize that!
okay im gonna try to find some new ones, hmmmm. okay so if i find a good set at the salvage yard how do i slide the seat back and forth to get at the bolts since there's no power to the car? any idea on what a used set goes for?
okay hopefully i can get a set out of a salvage car, but before i go tearing things apart... is there a way to correctly adjust my rails so they are tighter, is there any type of alignment of guide that i can adjust? or do i have to go ahead and replace them?
