94 Camaro Sputtering out
Hi I have a 94 Camaro z28 automatic, It has good compression, It has good fuel pressure and spark, It starts right up no problem but only runs for about a second or two then shuts off, It does it consistently every time. I have looked online, I put dry gas in it already, its not the computer, the fuel pump is good and if the fuel filter was clogged wouldn't my fuel pressure be bad. I can rev it up but after a second or two it just sputters out, almost like its out of gas. Because of the consistency I think it is a sensor that is telling the computer to cut the ignition. If you have any ideas let me know, thanks.
pick up a noid light for the injectors and see if the computer is telling the injectors to fire. whats the fuel pressure doing when it dies. i have seen a bad opti do this. do you have a way to scann for codes?
And the fuel pressure stays high as far as I know, I had a truck that had a bad fuel pump and the pressure would be good while running but once you turned it off the pressure would die, could a bad fuel pump be that consistent, because every time it shuts off after 2 seconds.
