94 camaro 95 camaro
is there any thing different between the 94 an 95 camaro
The OBD (on-board diagnostics) systems are different. 1994 cars still had the old OBD1 system. the system on '95s is slightly different, called OBD1.5. Also, 1995 was the first year the 3.8L V6 was offered. Other than that, I don't think there are any differences.
when i bought it for 1200 i thought it was a 94 but its a 95 (evenbetter)
lolz I guess you'll have to change your screen name then :icon_lolsign:
The 1995 Camaro's that had the 3.8L engine came with OBDII. They were limited to CA only and only with automatic transmissions. 94s were OBDI but you could not read the codes by jumping pins A and B, you needed to use a scanner for them.
Massey |
it still has the 3.4 5 speed
