-   93-02 General (https://camaroforums.com/forum/93-02-general-41/)
-   -   '94 A/c problem (https://camaroforums.com/forum/93-02-general-41/94-c-problem-40250/)
tazpilot Jul 2, 2009 07:03 PM
'94 A/c problem
I have a 94 Camaro......3.4L V6, standard transmission.
I know my ac needs to be charged cause it don't blow cold, but, it seems to be stuck on the defrost setting, regardless of where you set the control. I know it works off of vacuum, but, I can't find the bad one.....if there is a bad one.
Anyone have any clues, hints and tips for me to figure this one out????:icon_shrug:
Thanks all of you
craby Jul 3, 2009 08:31 AM
check the ac relay. have it scanned for trouble codes. ac should be throwing codes.
tazpilot Jul 3, 2009 01:37 PM
Vacuum line was off u nder the hood.......now all I have to do is find a AC compressor clutch and all SHOULD be well. I hope so......this car gets hot inside without cold air :icon_goofygrin:
craby Jul 3, 2009 03:13 PM
ac pump is under the power stearing pump. ac clutch is on the ac pump.
