93 camaro Key fobs?
93 camaro Key fobs?
Hey I was helping my dad program a key fob for his 96 impala ss, and as I was reading the instructions it said I could program my 93 camaro for a key fob. I tried it and it didn't work. Were the key fobs an option with the car or did they come standard? I grounded the wire for the obd reader to a ground and the locks didn't cycle.
http://shbox.com/1/4th_gen_tech2.html#1995keyless
Check out the link for programming instructions. I believe if you look in the trunk over where the spare tire is, there should be a small black box somewhere on the rear fender well if it has the option.
I took off the kick panel on the passenger side and there was no reciever there, but the place where it would sit was. Was keyless entry an option in 93 or not available?
Remote keyless entry was definitely an option. In my experience very few cars were equipped with it, at least V6 models. The easiest way to tell if your car has RKE is to look at the service parts info label stuck to the glove box door. Cars with RKE show option code AU0.
Of course you shouldn't bother looking at the label if your car doesn't have power door locks. But I'm sure you already knew that...
I followed the instruction to programming the key fob , but it is not working. after recycling the key three times to the run position, the doors locks and unlocks, when holding down both lock and unlock on the key fob nothing happens. any idea what causes this problem? could it be the key fob itself that I purchased on ebay?
Also, you should start your own thread instead of glomming on to someone elses.
Also am not sure why it is not showing my signature, propably I do not have sufficient posts yet. Thanks
Yay, I have my own signature now.
