5.3 vs LS1
5.3 vs LS1
Not having much luck with a 5.3 swap thread search. With the possibility of needing a head gasket on my 95 Z28 ($800 labor + parts) I'm thinking I would be better off swapping in a newer motor. I've found a 06 5.3 with 19K miles for $1300 and a LS1 with 6 speed for $2500. Thoughts on what is a better route (ease of job) I've seen a few post claiming the 5.3 to be pretty much a direct bolt in. I'm debating on the LS1 cause my 95 needs a clutch to so I could be up and running in 1 fell swoop. I could also rebuild the LT1 with 6 speed and put it in my Cutlass (1st car) that I'm restoring. If anyone has time to link me to some swap threads it would be greatly appreciated.
IMO if had blown the head gasket on my motor I wouldn't swap it. It would just be an opportunity for me to build my car or at least start some building. I would build my car if i blew my heads thats what my buddy did with his mazda RX7 he blew a coolant line in his apex seal so he built it now its pushing 400rwhp I saw the dyno it was pretty amazing
a 5.3 and an LS1 are essentially the same thing (minus an aluminum block)
that means, anything for an LS1 swap, you'll need for a 5.3 swap. The 4.8, 5.3, 5.7, 6.0, 6.2 and 7.0 engines are all considered part of the LSx family, so if you're considering any of these engine swaps, you'll need a wiring harness/ecu, engine, trans, coils etc etc etc
If you're planning on doing it, its a worthwhile swap, these LSx engines are absolutely amazing and even a highly modded LTx motor will still only run even with a midly modded LSx.
Why is there labor charges on the headgasket? You don't think that and engine/tranny swap and custom harness is simpler then a head gasket job?
Level of difficulty LT1 head gasket "4" (1-10 Scale)
Level of difficulty of swaping a different engine/tranny/computer system "8"
If my back was not bad I could for a head gasket in about 8 hours. I would want about 25 hours to change over Kmembers and install LS1 style motor & tranny
Are you thinking of doing this yourself?
