3800 to 350 swap
I have a 01 camaro that i put a older rebuilt 350 carbed motor in. the problem i have run in to is the carb is partially under the cowl. has anyone done this swap before and if so what are my options at this point?
I had 700R4 tranny that im using for now. everything worked out fine with that. the car starts, and goes through all the gears. but theres no room for a air filter, which didn't even cross my mind till it was to late. Hind sight is 20/20 unfortunetly.
I found this, Its with a Tubular BMR K-Member that is designed for old school SB and BBs. Not a whole lot of room for air cleaner. I would really injoy replacing the spark modual in that bad boy.
i hade to put new motor mounts in it and installed sub-frame connectors. its been a pain and a lot more work then i had expected but it does look and sound great! unfortunetly this air filter issue has me stumped.
