3.73 or 4.11 gears
Old 10-29-2011 | 02:09 PM
supafly147258's Avatar
Default 3.73 or 4.11 gears
ok im looking into purchasing some new rear gears for my Z and I was curious of which gears would give my car more power output?
Old 10-29-2011 | 03:13 PM
Nether one will give the car more power. What you really want to know is the amount of torque delivered to the drive wheels. The 4.11:1 gears will multiply the available torque by 4.11 times, while the 3.73:1 gears will multiply the available torque by 3.73 times. All things being equal, the lower gears (4.11 being lower than 3.73) will allow the car to accelerate quicker, up to a point, but you also have to keep in mind that the lower the gears the higher the engine must rev to to maintain the same road speed.
Old 10-29-2011 | 03:31 PM
Guitar's Avatar
And the greater chance you have of breaking your rear end with a hard launch! Yay!
Old 10-29-2011 | 04:39 PM
How do you figure that?
Old 10-29-2011 | 05:17 PM
3800camaro's Avatar
These 7.625" diffs are weak. There's some forums where guys with a v6 and 4.10s blow the diff apart.
Old 10-29-2011 | 09:23 PM
Guitar's Avatar
Well more torque to the rear wheels with a weak rear = easier to be blown...if people can blow them on stock power, then...
Old 10-30-2011 | 12:53 AM
Ah, but you said you'll break the rearend, that's why I asked to see what you meant. Getting a car moving with a higher rear gear, say a 2:73, puts more stress on the engine, trans, driveshaft, and ring & pinion. Lower gears, say a 4:11, lowers the stress on those components, which is why the engine and drivetrain now have a much easier time at getting the car to jump out of the hole. But, since lower gears act as a torque multiplier (after the ring & pinion), more stress would be put on the axle shafts. The entire rearend isn't in jeopardy, just the axles if they can't take the torque.
Old 10-30-2011 | 12:43 PM
shawnathan's Avatar
Are you going to street the car or is it strictly for drag purposes? If it's your daily driver I would say 3:73's
Old 10-30-2011 | 09:26 PM
imma street it mostly and occasionally take it to the track its always fun to track a car and see what its true potential is
Old 10-30-2011 | 09:55 PM
shawnathan's Avatar
I would go with 3:73's then.
