3.4 will crank wont start
i have a 95 3.4 v6. it will crank but wont start. i have never had to deal with computers before and was wonderin if that could be the problem. can anyone help me? the fuel pump works the fuses are all good. what could it be??
^^^ agree...take a plug wire off and stick a screwdriver in it and hold it close to a grounded surface like the exhaust manifold. have someone turn it over and look to see if there is spark. also take the intake elbow off the thottle body and spray a little gas in the tb and try to start. u can use a cleaned out window cleaner container to spray gas. only works for a short time then the plastic gets soft so dont leave gas in it.
