3.4 turbo?
new here, did a search for a while and couldnt come up with anything so here i am asking. i have a 95 camero 3.4 with a 5spd and wanted to turbo it. ive built many turbo kits for diesels so im compentent in doing the work and fabricating just new to the whole gas motor stuff. im going to use it for daily commuting and playing around but want some better power. i dont want to swap a big motor cause i want to keep the gas milage. it has 150,000 on it too. any ideas what i can use as a single or twin turbos? not looking for 600hp just a fun car.
thanks
matt
thanks
matt
The bigger engines can get just as good gas mileage as your v6. With that out of the way, there is a company who does this kind of work for not just the V8 and 3.8 F-body, but they also do it for the 3.4. www.force-fed-fabrications.com. If you contact them they could probably help you a bit more on the specifics. For their 3.4 I believe they just had a single turbo. The problem you will probably run into, is tuning the car. There isn't much in the way of tuning software for the 3.4.
Sixty7 Camaro
04-11-2009 12:54 PM
