3.4 1995 camaro v6
So after start up with no prob when cold & about 10min into warmup she stalls.Shes hard to restart, but does start but dies n stalls.Check engine light comes on and does not blink.Completed fuel pressure test & it read 32/33 is that low guys?Booke said 41+ planned on replacing fuel pump.Trapdoor method if so any ideas in this matter gr8ly appreciated.Happy Holidays
Simple things to test before getting it scanned would be testing the voltage coming from both the battery and starter, inspect the spark plugs, (If you plan on replacing the fuel pump, might as well clean the injectors and maybe some seafoam, remember to replace plugs after seafoaming). Getting it scanned will prevent you from replacing something that you didn't have to replace.
that is a little low but not real bad. should be about 37 when running. its doing this after it goes into closed loop. that would most likely be a sensor problem. find out what codes you have stored and let us know what thay are.
