17" rims front 18" rear
Anyone have a setup similar to this? im looking for bigger tires/rims in the back than up front does 17 in the front and 18 in the back sound reasonable with stock ride height and suspension? Im not looking for wider in the back tho. Should i go with 17x8.5/18x8.5 or 17x9.5/18x9,5?
RE: 17" rims front 18" rear
You can fit C5 Corvette wheels, OEM sizing is 17x9.5 and 18x10.5 I believe. I personally think that the Camaro looks better with the same size all around because the wheel wells are the same size all around. Like the Ovulator said, you can run 17x9.5 and 17x11, or 17x9.5 all around like the SS's came with.
