02 Camaro High Beam Low Beam Switch?
I was wondering if anyone knows if I need an adapter so that I can switch from my low beams to high beams? Currently I have a paper clip on the plug because otherwise none of the lights will turn on.
This is the picture of the switch with the paper clip on it.
I just wanna know where it goes connected or if it just needs a plug. If I take the paper clip out, neither high beams or low beams work.
I've looked and looked but haven't found anything. Any help would be greatly appreciated.
is the plugin down by your feet in the center or to the far left side? center, it wouild go to the dimmer switch that is mounted on or very near the steering column down by your feet. pretty sure you will have to take the cover off thats down there to get to it. if its offf to the left it would go to the light switch which im sure you know where it is. by the way your picture is to big. should be 640 on the big side. heres what i have for the 93, yours should be close to the same place.
I adjusted the switch on my daughters 98 and it is in the same place as craby's pic. I had to lower the steering column in order to get my 5 thumbs in there with a wrench to adjust it so it would switch from high beam to low beam. You might be able to reconnect the wiring without having to do that.
Thanks to all who replied. It was a bit difficult at first, but it turns out I was missing the complete dimmer switch where the plug went connected. Bought it @ an auto parts store cheap, installed it and it was good to go, although a bit difficult to screw on at least without taking off the steering wheel. After installing it, I found out the original one, and then was outta luck returning the new one...
So if anyone were to need one, pm me.
Thanks to everyone again!!
