00 SS Rearend.
Just picked up another rearend. Its from an 00 SS new axels, paid $100 bucks. Now looking @ it, I dont see any harness for the ABS. I have a 99 coupe that didnt have a posi. I replaced the rear with one from a 95 Z28. The ABS wont work due to the fact that they were two different systems. Looking @ the rearend I just picked up, I noticed there arespeed sensors on each axel. Do Ihave to buy a new harness for the 00 R/E ( I will anyways cause this one doesnt have one) and do I have to change anything else to convertmy carsPCM to tell it I am now running two speed sensors. The original rearend was a non posi with the speed sensor in the top of the rearend housing. Any help would be appreciated before I spend $$$ I dont have too.
RE: 00 SS Rearend.
You ended up getting a rear end from a car that was origionally equiped with TCS, you need to find one that did not have TCS and it will have the single wheel speed sensor that you need.
RE: 00 SS Rearend.
Sounds like you had a 3 channel (sensor running off the sun gear on the carrier) and your new one is a 4 channel (Traction control car) rear end, your best bet is to sell the one you just bought and look for another 3 Channel.
Try LS1tech,CamaroZ28.com they always have someone selling a 10 bolt (you want w/o TCS) |
RE: 00 SS Rearend.
is there any way of fooling the pcm to thinking it is only running one sensor?
RE: 00 SS Rearend.
ORIGINAL: Chappie99 is there any way of fooling the pcm to thinking it is only running one sensor? |
RE: 00 SS Rearend.
do you have to keep your abs? i deleted mine.
RE: 00 SS Rearend.
yeah i did the same to my 95z28 camaroi used to have. i bought a rearend to a 94 z28 camaro. my 95 camaro had thetraction switch and the abs. the rearedn i bought did not have the traction control. i still hook it up i just didnt have the traction control or abs wasnt working. the car ran no diffenrent. only thing i noice different was if i slammed on the brakes really hard the car would slide but still stopped on the dime.
RE: 00 SS Rearend.
The car stops fine. The reason I am intrested in fixing the problem is that in the State of Masschusettes if there is any warning light on in your dash, it fails for a sticker. So, if I delete the ABS, this should take care of it? What do I need to do this, a reprogramer?
RE: 00 SS Rearend.
Didnt some of the V6 coupes come with the posi rearend? If so, I should beable to utilize this function.
RE: 00 SS Rearend.
Some 6ers came with a posi. That's about the extent of my knowledge.
