Wiring?
Wiring?
I probably posted my car current set up before but lemme say it again for my problem.
I bought my car for 500 stock motor was swapped with a carb 305 smallblock. So basically what I need to know is the best way to go about this everything in the car is basically fuel injected set-up and it also has the 85mph dash, and I want to wire the car correctly or at least so everything works without any problems. As of the moment my fan and starter are wired to two different switchs.
So has anyone have or had a problem like this and can gimme some ideas to fix it?
Hey, im not 100% sure how to fix your prob without using an older engine bay harness. do you know what year the motor is? maybe use a 2nd gen harness on it? but the 81 was the first year they used the computer.
Or you might have to reroute some wires but i wouldnt know where to start with that.
maybe do a google search, ya never know what you can find. maybe someone else had a prob like that in another forum?
joe
joe
