where to run mechanical oil pressure gauge
Old 02-28-2009, 02:18 PM
1989_RALLYSPORT's Avatar
Default where to run mechanical oil pressure gauge
ok i cannot find any free ports to run the oil pressure tube to on the engine
please help soon as its a nice day today and want to get this done before it drops back to the 20s tomorrow
*edit* its an 89 305
Old 02-28-2009, 03:11 PM
Jr. Mechanic's Avatar
August 2009 ROTM
Should be a port where the stock sender screws into on the back deck of the block, directly on the intake mounting surface.
Old 02-28-2009, 09:23 PM
is it on the intake or the block?
i see one on my spare block at the top but i thought that may have been covered by the intake on mine. ill check for it on mine tomorrow
why isnt there any other holes for it?
theres another hole near the oil filter besides the stock sensor but theres nothing in it i can stick a piece of wire about 5 inches in. the hole leaks nothing though
Old 03-01-2009, 12:12 AM
The stock sending unit screws into the block, drivers side, below the exhaust manifold.
There is a small square plug screwed into the back of the block, right behind the intake manifold. That would be the perfect place for the oil fitting, but it's going to be a lot of fun getting the plug out since there isn't a lot of swinging room between the block and firewall.
Old 03-01-2009, 12:19 AM
August 2009 ROTM
Huh. Mine was in the port behind the intake, but I have no clue what the PO did. Anyways, my oil pressure gauge is running off the port behind the intake, and is easy to get to without the distributor in.
MKCoconuts
05-13-2012 11:47 AM
93bumblebeeCAMARO
02-15-2012 05:43 PM
josh95camaro
10-09-2009 10:15 AM
jtd_1
07-01-2007 08:17 PM
Quick Reply: where to run mechanical oil pressure gauge
