where does it go?
That is a filter that goes to your brake booster. The other end either goes to the intake manifold for vacuum or if memory serves me there is a fitting on the back of the carb on the lower portion for it.
And you can reply and put pics in your orginal thread
![Wink](https://camaroforums.com/forum/images/smilies/wink.gif)
You should have a pipe coming from the manifold that does a "whoop-de-do" up and over the rear portion of the drivers side valve cover. The short rubber hose on the filter goes on that line and the right angle fittinggoes to the power brake booster.
at the risk of sounding like a dufus LMAO. unless your a perfectionist and your gonna lose sleep over it. tieit to a fishing line and use it as a sinker. you will never miss it Sick
That engine compartment reminds me of my 84's. Except I had the Chevrolet chrome covers and timing cover and the triangle Edelbrock signature series and when I put all that on the engine was clean! ![Big Grin](https://camaroforums.com/forum/images/smilies/biggrin.gif)
Was your Check Engine light on before? If not then go back over what you did. you may have unplugged a wire and forgot it.
ORIGINAL: MadMikeZ28
No the filter wont be missed. You don't see them on newer cars. But the connection between the booster and the intake will be missed.
Ya Dufus
Ya Dufus
since I replaced my air filter housing, do I still need to use this sensor. Two problems I'm having choke light, and engine light. Car is running better, but now having trouble starting? what the hell!
[IMG]local://upfiles/9678/E604AF1E097545DF8F222816BDAA38F6.jpg[/IMG]
