-   82-92 V8 Tech (https://camaroforums.com/forum/82-92-v8-tech-13/)
-   -   What kind of engine can i put in a 1986 camaro? (https://camaroforums.com/forum/82-92-v8-tech-13/what-kind-engine-can-i-put-1986-camaro-31051/)
CAMAROfan29 Aug 26, 2008 09:20 PM
im looking at a 1986 camaro right now. the body work is done and it has been freshly painted. has 5speed trans, clutch, flywheel, bellhousing etc, just needs an engine. it was origianlly a v8. guy wants $750.
my question is, what size engine can i fit in this? i want the biggest i can use with a stock trans. no racing or drag for it, just want it to be fast for the road. i was thinking about buying a used one from a same model camaro and rebuilding it, but i was wondering if i can use an even larger engine and rebuild that instead? thanks!
97SuperSport Aug 26, 2008 09:28 PM
RE: What kind of engine can i put in a 1986 camaro?
With the stock transmission you will only be able to put a 305 in it safely. While I have seen a 350 in one, it shreded it pretty quick. The T5 Tranny isnt a very strong one by any means. Thats why you never see an Iroc 5 speed with a 350 stock. T5 couldnt handle it.
