What i am going to need
No its a v8 305 though and i want to put a 350 in there cuz it is better to build one of those from want i have heard could you tell me how to get to the v8 swap menu please and thanks
not really the 350 will drop right in place of the 305 b and m makes a adapter bracket to bolt the trailing arm to the 350 tranny or you could just use the tranny thats already in it
if you plan on taking your car on the highway, and still be able to pass a few gas stations then I wouldnt use a turbo 350 or 400 unless you plan on changing the gears. But other then that it depends you are going carb. or fuel injec. on the parts you will need.
I agree with Camaro1984, a 305 is basically a 350 with a diffrerent crankshaft. I see no reason why it should mount any diffrerently than the 305 and the tranny you already have should bolt right onto the 350. Should be a fairly easy cheap swap, nothing out of this world. Just like with any swap you have to do some research.
