turning a 305 manually
i have to turn the engine over manually and im unsure on how to do that i was told by the crank shaft nut which sounds right but i am unaware of how to do that if any of you know how to do it well and could provide me with directions on how to do that or provide me a link to a site that could help me out i would just bring the marro to a pro but it is stuck in my garage untill i can figure this out any help is greatly apperciated
thanks
1985 camaro 305 base coupe
thanks
well assuming you are talking about just turning the innards most likely to bring it up to tdc then yes its just using a socket wrench on the end of the crankshaft nut. however if you are talking about trying to start the engine then i dont see you accomplishing that. there is no way you can manually turn it fast enough for it to start
hmmm i would think those engines would be a lot easier to manually than these engines....but i may be wrong! lmao. would be kind of an interesting story though.
yeah i was trying to bring my engine up to tdc and i put the breaker bar on and turned then all of a sudden it just fired up. breaker bar went right through my radiator =[ lol
That's the way it used to happen back then, except it meant for some broken fingers or worse if the engine kicked back. And before any smartass says anything...NO I wasn't alive back then!
If you plan on doing a lot of hand turning, removing the spark plugs will make the job a lot easier.
I wasn't either but I used to have this old 1937 CAT 22 with a hand crank starter so I know how to start the old time stuff.
