-   82-92 V8 Tech (https://camaroforums.com/forum/82-92-v8-tech-13/)
-   -   throttle cable (https://camaroforums.com/forum/82-92-v8-tech-13/throttle-cable-52177/)
crazystang25 Jun 1, 2010 04:03 PM
throttle cable
hi i just have a quick question, my brother has an 84 camaro that had a sbc already swapped in it. the problem is it was originally a v6 car and now with the sb swapped in the v6 throttle cable has broken and has given plenty of issues with it being too long. so should i just buy a lokar v6 cable to replace it or try to find a v8 pedal assembly. also its carb'd if that makes a difference.
microkid Jun 1, 2010 07:25 PM
just go to a junkyard and get a cable and carb bracket from a v8. i think the tbi setup will work as well, but im not sure on that.
cperkins614 Jul 6, 2010 04:02 PM
I've had trouble wih my cable breakin on my 92 Z28 TPI. You should just be able to get one for a small block an work just fine. The only place i could find one for my car was YearOne, all auto stores i went to didn't have the right one. An YearOne was an Original GM part.
