Is there a charge light that comes on for 1990 camaro
Old Feb 15, 2010 | 06:07 PM
1990z28tpi's Avatar
Default Is there a charge light that comes on for 1990 camaro
Is there a charge light that comes on when the battery gets low in the insterment panel.. And if there is where is it thanks.. Jesse
Old Feb 15, 2010 | 07:57 PM
No, there isn't one. You have to look at your gauge, the upper right one between the speedo and tach.
Old Feb 16, 2010 | 02:04 PM
1990z28tpi's Avatar
Yea i know there is a gauge but sometimes there is a light that comes on.. My alternater was not charging someone said that sometimes if the light is out the alt will not charge but anyway I figured it out it was the brown wire on the alt that goes to the fuse box there was a dead spot in it so I cut it and ran it direct to the alt seams to be working fine know thanks...
Old Feb 16, 2010 | 02:52 PM
Do you remember where the light was that was going on (which spot on the gauge cluster)? I have a spare 1990-92 cluster in a box, and pulled it out to see there wasn't a charging light. Just curious which light would have been going on?
Old Feb 18, 2010 | 05:38 PM
1990z28tpi's Avatar
No light came on in my car just talking about other cars like my blazer as battery light and a gauge.. Any way no problem fixed the problem took the brown wire from the plug on the alternater and hooked it to a 12 volt source alt charging fine know..
Krw416
Mar 24, 2012 03:56 PM
stealthwizard89
Jul 19, 2010 10:47 PM
eion014
Jan 12, 2009 01:53 PM
p3313r
Apr 13, 2007 02:36 PM
1968CamaroFl
Jul 16, 2006 09:16 PM
