th350 install with hurst #5500001
Old Dec 26, 2009 | 08:19 PM
turo72's Avatar
Default th350 install with hurst #5500001
I'm about to install a th350 trans using the hurst install kit #5500001. I was just wondering if anyone out there has used this and can give me a heads up on any problems I might run into. I already got the kickdown cable so help in adjusting that would be much appreciated too.
Old Dec 27, 2009 | 11:27 AM
Pretty straight forward if you follow the instructions. Just be very careful when adjusting the cable to make sure it travels through all gears selections, and goes fully into park. If you manually put the tranny in park, then put the shifter into park position, the linkage should connect right up if everything is properly adjusted. From there it should all work.
Old Dec 27, 2009 | 01:22 PM
turo72's Avatar
Thanks for the help I'll post some pics of the install just for s&g.
turo72
Jan 12, 2010 10:43 PM
brian_rs/ss
Apr 3, 2009 10:51 PM
6426yy
Jan 10, 2008 10:38 PM
Pro_built7
Nov 26, 2007 08:48 PM
7d9_z28
Nov 18, 2007 11:50 PM
