Starting after warm issue
i have an 85 camaro and when i drive it till it gets warm then shut it off and let it sit over 5 maybe 10 mins it will not start for the next two hours. i have recently replaced the cold start sensor, fuel pump, fuel pressure regulator, plugs, wires,, cap, rotor, coil pack. it still doesnt want to run right. since i replaced the FPR it doesnt hesitate like it did while it was warm but still acts up cold. Any help will be greatly apreciated.
what bout checking the starter or fuel injectors?
starers fine cranks everytime and doesnt crank weak and i have ran injector cleaner through multiple times. correct me if im wrong but if it was a faulty injector wouldnt it do it all the time not after i ran it till it was warm and had it off for 10 mins.
well i was look at this post from thirdgen.org Every few months, TPI won't start????? - Third Generation F-Body Message Boards a few of them said it was the injectors for them that some went dead
