rockers
Old Nov 16, 2007 | 01:51 PM
xPBxWrEckeD's Avatar
Default rockers
what size feeler gage should i use when tightening the rocker arms down.
Old Nov 16, 2007 | 03:44 PM
Default RE: rockers
The right size. LOL. I assume you arereferring toa solid lifter cam which is usuallyinstalled inall out engines. That being the case, you need to find out the brand cam, and then ask the people that ground it what the clearance should be. If you have hydraulic lifters like most engines use, then there is no need for feeler gages.
Old Nov 16, 2007 | 08:42 PM
Default RE: rockers
i have hydraulic lifters... my dad told me to do it because thats the way we do it on farm tractors.
Old Nov 16, 2007 | 08:58 PM
MadMikeZ28's Avatar
Default RE: rockers
On the farm do you also compare apples to oranges. Unless you have done any work there the hydraulic are no maintence.
Old Nov 17, 2007 | 06:09 PM
Default RE: rockers
ok so whats the right way to do it?..i put in 2 new lifters..the rockers are all loose..went through all to find the bad lifters..its an 89 305 tuned port..a link to a site with how to do it would be nice thanks
Old Nov 17, 2007 | 06:24 PM
Default RE: rockers
You put in 2 new lifters only? What you should have replaced was all 16liftersand a new cam, and a new timing chain set while you're at it. Each cam lobe and lifter wear together as a set. Putting a new lifter on an old cam is opening yourself to some wear/galling issues on the cam lobes. Prepare yourselffor a premature cam lobe (or two) failure in the future.
Old Nov 17, 2007 | 09:18 PM
Default RE: rockers
yea i see what u mean...but how premature..cuz i am gonna put in a new cam in about 4 months..this was just a quick fix for now..only going to be driven for a bit since winter is coming.
Old Nov 18, 2007 | 01:20 AM
Default RE: rockers
There really isn't a defined timetable to say it will go out on "X" day, and since a very short term is the plan, go ahead. Since you're replacing everything soon anyway, you don't havemuch to lose.
Old Nov 20, 2007 | 12:02 AM
MadMikeZ28's Avatar
Default RE: rockers
ORIGINAL: xPBxWrEckeD
Since you only did 2 I will give you the short way of setting up the preload.
Turn the engine until the cam lobes are down. Valves closed. loosen the rockers if they are tightend now and then turn the nut until you remove the lash from the pushrod. Oncethe pushrod stops turning by finger then turn the nut an aditional 1 1/2 turn.
When you do all 8 cylinders then you have the engine on #1 TDC power stroke (look at the position of the dizzys and it should be where #1 fires) and can adjust exhaust 1,3,4,8 and intake 1,2,5,7. Rotate the engine 1 complete revolution and adjust the other valves.
You may hear just start the engine and get it up to operating temp and tighten the nuts until the noise goes away but I consider that the stupid back yard mechanic way.
VALHAR
Oct 9, 2014 12:19 PM
CamaroDreamer
LS Series Tech
Sep 22, 2011 09:47 PM
DKap22
Mar 14, 2007 07:52 PM
WMadam11
82-92 V8 Tech
Feb 25, 2007 09:20 PM
camarokid1968ss
Apr 23, 2006 12:34 PM
