quick ?
quick ?
I have a quick question you might have seen my other posts but my 87 camaro has ran a best of 12.10 at 113 with 2.73 gears with a th400 trans 26" tires. i only use 2 gears through the 1/4 mile i shift into second at 6700rpm and and cross the line at 6800 rpm in second gear. i had just put a set of 4.10's in it put a 3 gallon cell up front and got some control arm relocation brackets. my question is since i went with the 4.10's i heard my trap rpm will only be like 6100rpm in 3rd will this cause me to run slower time since im not turing a higher rpm like before or will it be about the same. Im hoping to hit around 11.70 . also taking front bumper support off and of course the stock gas tank think i will be able to do it.
