Parts HELP
ok if you are looking to change the center section aka carrier, in almost all cases it will cost more and be considerable more work than it is to change the entire rearend. to tell for sure if you have traction control, look at the rearend, if it has wires going to sensors on each rear wheel at the area of the brake calipers then you have traction control. if you have wires going to the center section of the rearend only then you have abs only. any rearend from a 4th gen camaro will fit so long as they both have either abs only or traction control. abs only=3 channel, traction control=4 channel. if you are looking for option codes they should be on a sticker in the glove box or in the console or on the door. codes are 3 character codes having letters and numbers. rearend carrier gear ratio is shown as gu2=273, gu5=323
lol, does any of this help?
NO 3rd gen came with Traction Control....End of that line. Positraction = Limited Sip...End of that line also. Cost of Two Wheel Burnout..Priceless.....
holy smokes im in the wrong section again. v8 section gets me again, time to wake up. lol thanks black. well scratch most of my post. sorry bout that guys.
