need help how to save gas
i just got a 93 z28 and its a real good car but my gas is gone by the nexts day and all i do is go 2 work an some other places so is there any way i can save my gas by buyin anything thanks
$chevytime$
$chevytime$
How many miles are on it? If it's over 100,000 definately get a full fuel system cleaning, replace the O2 sensors and have you had a tune up? Check your fuel filter too. Transmission fluid changed? Rear differential fluid?
ORIGINAL: shnormo
You're forgetting the distributor rotor in general tune up stuff.
If you would like to get technical
Spark plugs
wires
timing
check your thermostat make sure it opens right and it has the right temp range
check the radiator cap
(OLD SCHOOL)
cap
rotor
points
The biggest fuel waster is probabbly a dirty air filter, fix any check engine lite troubles, keep tire inflated, always drive downhill. You really have the wrong car if you want economy. A 6 cyl would have been a better choice.
