need Help with a fouling problem
Old Mar 2, 2008 | 12:51 AM
age84's Avatar
March '09 ROTM
Default RE: need Help with a fouling problem
Final Update
After having the carb rebuilt it did not fix the problem all the way but it was a big part of it I had it jetted down from a No, 72 to a No. 69 made a big differance but was still running rough. When I put the timing light on it the timing markwas jumped everywere and yes i pull the vac. advance hose off here is what i did that made it runlike crapi crossed the coil wires in the dist. cap it fried the cap and rotor Very stupid on my part you think it wouldn't run that way put i did and the tach kept on working with no sign of any problem.I hadput a new HEI module in it a while back and never check the timing and it changed the timing alot anyway did the timing ajusted the carb a little to get the fast idle and the idle set and now it finally runs pertty good still needssome fine tuning but it is damn fast now andno fouling
Thank's for thehelp
IROCYOURVTEC
82-92 V6 Tech
Oct 20, 2010 01:01 AM
Beest
Jun 27, 2010 02:42 AM
IZZY1967RS
Jun 15, 2008 11:11 PM
2lucke4u
Sep 1, 2006 09:55 PM
