'84 Z28 ... is the clutch (stock) hydraulic or no?
look at the trans if its hydraulic there will be a slave cylinder to push the clutch fork if its manual than there will be a cable going to the driverside... also you can look in the engine compartment if you find a little reservoir thats for a hydraulic clutch
Where would the reservoir be exactly?
