making a T-Tops
RE: making a T-Tops
no idea how much it would cost, but my brothers firebird had it done with custom sized tops, making it impossible to find a replacement so make sure theyre cut out to OEM spec in case one breaks
RE: making a T-Tops
thats rediculous if that how you spell it, V6???
Dont listen to that fool. JK, I heard that if you take the skin off of the roof, it would be easy. Dont know about how well it would seal. Not to mention take value off of your car. ( remember those aftermarket sunroofs on 69's) yep same thing, value will be lost and down the road it wont look as nice.
Its your car though, make the decision yourself. Or buy a new camaro with t's
RE: making a T-Tops
Cutting the roof is not recomended, specially with a built up v-8. The roof provides structural support. Therefore require reinforcement. If you take the GM's aka pontiac with the 6.6L 400 block, they had factroy subframe connectors only with t-tops. So if you want to have them custom cut, just remeber you're looking at either subframe connectors or a roll cage meaning more weight.
