KNock sensor?
if it has one, which im not sure of, will be on the passenger side of the block. its round in shape and has a one wire plug. here is what it looks like. it works in a rather interesting way. i forget whats inside (i think its piezieolectric), but when there is a hard vibration, it produces a voltage and goes to the ecm to tell it that there is a knock and it retards the timing
that looks like the one I'm looking at.
javascriptopImage('http://shop.oreillyauto.com/product_images/img/bwd/s8003_full.jpg',%20'BWD+Automotive%20S8003');
I am looking the wire diagram and trying to find a wire that leads to it, but I do not know if there is even a place for it on an '83?
That would be OK, one less thing to worry about
Parts application guide shows your car had a knock sensor. But, since yours came with no more than a 305, the 350 is a transplant. If the 350 has a knock sensor, and you're still running the factory computerized distributor, you do still have something to worry about if it isn't hooked up....a crappy running engine.
