how do u do this?
i have two camaro steering collumns, one is a parts collumn that has a good turn signal/windshield washer switch in it, my question is: how do i swap those switch along with the wiring into the other collumn
pretty simple actually, pull the wheel off(depending on model it might have a second peice the wheel bolts onto as well, take that off till your left with just the gear sticking out, theres a metal bring that goes around that gear u need to pry it off carefully without breaking it or letting it shot half ay across the room as theres a spring under it, once u get it off the plate and sprign will come out with it(pop out, be carefull) once thats off, theres a i beleive 3 screws going thru the plastic peice that is you turn signal crap, just disconnect the wires and thats it, o theres also a little metal peice connected to it make sure u put that back on correctly or your turn signal switch wont work right. and the installion is the same, but have fun getting the plate and spring back in and then that clip, trust me it sucks i just did it for a igniton switch.
