got lucky as **** today
Old 08-03-2010 | 03:08 PM
91camaro350's Avatar
Default got lucky as **** today
hay all well good news i got my tranny today had to get it out of the junk yard but when i pulled it i looked where the shaft comes out to go into the engine and the seal was new so i was wondering what else was replaced so i pulled the pan off and all of it was new and has a shift kit in it isnt that some **** i got a great tranny lol well i do have a question at the junk yard the put a hole in the tranny to drain it but they put a rubber plug in it and it took me a min to get it out fits reayy good in it will this be okay or do i need to replace the tranny any ideas any of u get one like this or what i think it will be okay but not sure let me know
Old 08-03-2010 | 04:33 PM
I take it you mean the hole is in the pan? A rubber plug will likely blow out once the fluid gets hot to soften it, and with pressure against it.
So what did you get, a 350 or 700?
Old 08-03-2010 | 05:56 PM
700r4 it was the easyiest way and thing to get and the one i found dame i love how it looks on the inside lol
Old 08-03-2010 | 06:03 PM
also when i got to the junk yard i knew they only had 2 or 3 camaros that would work with mine after i found out that none of them had trannys i went after the firebirds and with luck i found one a 92 and it had the tranny it came out of a v 6 and a guy there that was a tranny guy told me it would work with my 350 since it was the same bolt pattern so if it wasnt for this guy i wouldnt have found this tranny thank that man lol
Old 08-03-2010 | 07:16 PM
I hate to tell you this, but you're gonna want to go find that "tranny guy" and give him a swift kick in the nuts.
The v6 bellhousing bolt pattern (other than the 4.3 that wasn't in an f body) is smaller than the v8. It isn't going to bolt up.
Old 08-03-2010 | 07:20 PM
Stix80's Avatar
but he should be able to use his old bellhousing correct
Old 08-03-2010 | 07:22 PM
The trans is a one piece unit, no separate bellhousing. Separate bellhousings didn't come until 96 with the 4L60E.
Old 08-03-2010 | 07:29 PM
Stix80's Avatar
ok didnt know you learn something new everyday
Old 08-03-2010 | 07:32 PM
are u ****ing kidding me u have got to be jokeing no way in hell it will work plz dont tell me that
Old 08-03-2010 | 07:47 PM
Jr. Mechanic's Avatar
August 2009 ROTM
No, a V6 transmission won't work. Time to put it on CL and find another transmission.
