Good or Bad Set Up for TPI?
Im thinking of installing intake runners,tunning kit,3.73,pulleys and headers the thing is i dont know whos the best in intake runners SLP or Edelbrock?this is for SLP http://store.summitracing.com/partde...&N=700+150+ and this is for Edelbrock http://store.summitracing.com/partde...&N=700+150+ , about the tunning kit its includes air filter,wires,spark plugs,coil,thermostat,distrebuter cap and rotor,fuel pressure regulater and fuel pressure gauge is this recommended for a 1992 camaro that has been in the garage since 97?the car runs very good but i think it needs this tunning kit,about the pulleys do i need to install 3 peice March pulleys or it wont do much to my car? about the headers it will be Hooker Super.comp shorty with Y-pipe this is the headers http://store.summitracing.com/partde...p;autoview=skuand i want to install every part that dont needa chip for the ECU because it is very hard to find in my country and any near countrys so what do u think?any suggestions?
RE: Good or Bad Set Up for TPI?
I have The SLP runners and SLP 1 3/4 Stainless Steel headers. I would look at the stainess for headers the Hookers will rust out on you. Tune up items ok, also check the hoses and change all the fuilds. Forget about the pullies they are a waste and will result in more problems then they are worth. Nothing you are doing requires and chip upgrades.
[IMG]local://upfiles/2696/E19D81AD742E4A9882753C34DAC849E2.jpg[/IMG]
ORIGINAL: White Zombie
btw my camaro is 1992 25th anniversary
[IMG]local://upfiles/2696/345BC0C817A941C08A28E3F05C8FF5DC.jpg[/IMG]
thanks for helping me guys,i saw a camaro with SFCs and i didnt like the results so i will go for Lakewood control arms and panhard arm,what about the STB?i saw some 3rd gens with 4th gens STBs !! and i want a lowering kit for my car whats the best i order coil springs with shocks or only coil springs?i found a lowering kit from Intrax it lowers the car 2" drop or what do u suggest another company?
xStangHater07x
02-22-2007 04:23 AM
