Fuel pump and sending unit question
Old Apr 26, 2008 | 01:35 AM
snapper08's Avatar
Default Fuel pump and sending unit question
I need a new fuel pump sending unit for my 1983 cross fire injection, but they are not made anymore. I know you can use an Iroc Z fuel pump on them because the left throttle body regulatesthe fuel pressure so I have heard, but can you use a fuel pump sending unit for an Iroc Z as well or is there another sending unit that will work with the CFI? Please help
Old Apr 26, 2008 | 02:45 AM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Default RE: Fuel pump and sending unit question
Have you looked at classic industries?
Old Apr 26, 2008 | 05:59 PM
MadMikeZ28's Avatar
You may also be able to use the sending unit for the TBI. I would also imagine a sending unit from any of the fuel injected models as long as you use the correct pump that matches the PSI and GPH needs of the cross fire.
Old Apr 27, 2008 | 01:04 PM
snapper08's Avatar
my fuel pump is fine the sending unit is bad, and all i can find for 3rd gens are 85-92 so will one of those work?
Old Apr 28, 2008 | 02:08 PM
MadMikeZ28's Avatar
They should all fit in the tank properly and as long as its from a fuel injected car it should have the sending unit that has the electric pump holder. As to the fittings being correct I can not say.
The reason you can only find from 85-92 may be due to 85 being the first year of TPI (also MPI V6 and the exception of the TBI 4 bangers) and thats more common that CFI
Larry R
67-69 I6 Tech
Jul 14, 2017 09:38 AM
88cam23
Jun 17, 2010 01:08 PM
Thoreau
Feb 21, 2009 10:59 PM
systemsmack
82-92 V6 Tech
Jul 10, 2007 08:40 PM
89 Iroc Conv
82-92 V8 Tech
Apr 5, 2007 01:25 AM
