fuel line
i am going from tbi to a carb the fuel line is on the driver side the carb inlet is on the passinger side does any one know if i can run a rubber fuel line or a steel line from the pressure regulator to the carb what is the best to use. thanks
So I take it you have an Edelbrick carb?
A good (and safe) rule of thumb is to run as little rubber hose as possible. You want to run a steel line from the regulator, and you can run it along the firewall to where you will make a bend towards the engine. Then a rubber or braided hose from there to the carb, if it's not a real long run. If you're wanting to go braided all the way, then it won't hurt to run that in place of steel line.
