Car Dies Random without accelerating & on Turns
Old Nov 1, 2012 | 05:07 PM
nickcamero89's Avatar
Angry Car Dies Random without accelerating & on Turns
Hey guys, I just purchased an 89 Chevy Camero V8 5.0 and have had a number of problems already.
1st - its had an overheating problem out of nowhere so I replaced Thermostat and it seemed to fix the problem except for it will randomly heat up and then drop back down to normal temp out of know where. But doesn't die, doesn't bubble, doesn't turn the car off or anything.
2nd - The car will randomly shut up, either right when i start it, or if im not accelerating going straight and whenever i make a left turn, sometimes right. As long as I have my foot on the gas a little, it wont die, but otherwise it randomly shuts off, then will start back up. Battery Voltage levels on the Dash will go from half way down to almost nothing and go back up. Never have owned a Camero.
Old Nov 1, 2012 | 07:52 PM
torque_is_good's Avatar
plugs, wires, cap, rotor, fuel filter and see if it improves
Also, I still have an 89 factory service manual and a haynes manua:l $35 for both and includes shipping. They are invaluable
Old Nov 1, 2012 | 11:26 PM
Does the engine start right up (when it starts), or do you have to crank it for a bit?
When you turn the key on, not start, can you hear the fuel pump prime for a few seconds, then turn off?
Old Nov 7, 2012 | 05:55 PM
I can hear the fuel pump prime, and it starts right up with no issues. Now it dies suddenly unless I have my foot on the gas. Before it would at least idle, now even if I'm driving down the street it dies as soon as I let off the gas pedal.
Old Nov 8, 2012 | 10:44 AM
The voltmeter going to zero could indicate a bad wiring/cable connection, or a wire/cable shorting out. No voltage at battery = no spark at plugs, unless you are using a magneto system. Start by checking the battery and ground connections.
SavPR
Jun 19, 2015 11:56 PM
thor9812
Aug 29, 2010 12:14 PM
White94Z28
Mar 14, 2010 03:36 AM
Bzman
Apr 14, 2008 10:22 AM
psycledad
Feb 20, 2007 06:21 PM
