can't hear the fuel pump on an 86 Z28!!
I have an 86 Z28 305 TPI. Is it a blown fuse or a relay or the pump itself died on me? The car has been sitting for a year now. Had a new battery and a few gallons of fresh gas with no success. Haven't been able to work on it since I am overseas right now. Finally got my dream car after years of waiting, can't wait to get it running!! Hopefully someone knows as this is common problem on these cars. Thanks.
check all the fuzes and the relays if they work fine then drop the tank
yup, should be a rather easy fix, check the obvious culprits from easiest to hardest, sounds like you have an understanding on what it should be
