Cam for my build
Old 07-28-2011, 09:58 PM
91TealRS's Avatar
Default Cam for my build
350 Flat top 30 over. Heads I dunno yet what I'll yet.
Car is auto too btw.
Here is a cam I have. Bracket Master II Cam - Chevrolet Small Block 284/284 - Lunati Power
Advertised Duration (Int/Exh): 284/284
Duration @ .050 (Int/Exh): 218/218
Gross Valve Lift (Int/Exh): .458/.458
LSA/ICL: 110/106
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 1500-5200
Old 07-29-2011, 05:20 PM
91TealRS's Avatar
LSA/ICL: 110/106
BTW: I don't know much about those numbers or what they mean for me. Also if it will be good with this engine and I need too find some good heads. Right now all I have are some 882 heads.
Just wandering what too expect and if it's a decent cam or not.
Old 07-29-2011, 06:11 PM
Should be nice, but it is a flat lifter cam. What year block are you using. If it is a 91 like your sig seems to indicate, the block is machined for factory type roller lifters.
Old 07-29-2011, 06:42 PM
microkid's Avatar
March 2011 ROTM
Technical User
what sort of induction will you be running as well? that is a decent cam for a car that will be driven on the street often
Old 07-30-2011, 04:24 PM
91TealRS's Avatar
block is a 70's block. Old 010 350 block. I think 3980010 but I forgot.
Old 07-30-2011, 04:35 PM
91TealRS's Avatar
Going too be carbed since I have a edlebrock performer rpm on the factory 305ho now. Car was converted too carb when I got it. Going too be street driven and might hit the strip a few times.
Old 08-01-2011, 12:15 PM
microkid's Avatar
March 2011 ROTM
Technical User
the cam should work well with the setup you are running
Old 08-01-2011, 10:28 PM
91TealRS's Avatar
Cool thanks
fbodyrs96
04-19-2014 01:59 PM
nasstySS
03-21-2012 08:42 AM
Oil guy
04-17-2009 07:41 PM
1981TypeLt
02-19-2009 10:21 PM
gomez101380
82-92 V8 Tech
11-27-2008 11:14 AM
Quick Reply: Cam for my build
