10 bolt ????????
10 bolt ????????
Ihave a 83 camaro putting down big numbers, motor swap trans upgrade and many others, i need to find a budget way of beefing up my single out put 10 bolt. i thought about a mini spool, or swaping rearends with a new limited slip. also how can i find out the spline? aslo what will the axles hold up too on HP and TQ[/align]
RE: 10 bolt ????????
if it's the factory rearend it's 26 spline , and they are quite weak. your if you want a strong rearend gear a 12 bolt that is made to go into your car. http://currieenterprises.com/cestore...e.aspx?id=1091check with thse guy's , they know 12 bolts.
thanks, i have seen those online there a little more than i wanted to pay, but i guess thats what i have to do to be able to support the power iam trying to put down, i have thought about get a junk yard 12 bolt and cutting my old mounts down and wedding the junk yards in its place, iam worried about setting the right pinon angle, should i just bite the built and buy a new one or will the junk yard work?
bite the bullet , let someone else do the hard part and you reap the benefits. plus if you buy from Currie or another high rep. manufacture you get a warrenty, unlike a junkyard. you can also order them with your choice of gears , limited slip , and with disc brakes if you want . again , unlike the junk yard. and always remember when it coms to performance parts.....you get what you pay for....
