bigpoppasmurf |
05-08-2009 04:26 PM |
oil pan sound?
Ok, so I just got this 1992 RS...180,000 MILES ON IT..QUESTION, there is a knocking sound that I believe is coming from the oil pan.Thought it was a pushrod but no harsh sounds were heard using a stethascope.I changed oil,plugs,wires and redone the timing(the guy I bought it from had a bad module in it,2 plug wires in the wrong place on the distributor,and it wasn't even clamped down.There was a slight crease near the drain plug I noticed when I changed oil and filter,not big but I can't tell if the pan is hitting something on the bottom of the engine.Oh btw,i have great oil pressure all this time..any help would be great as I left my 1991 Eclipse for the Camaro.
