ECM Problem???
ECM Problem???
Hello..I have a '92 RS V6..
The problem..Sometimes when I try to start it ..it will turnover but not fire at all.If I just turn the ignition key to the start position but not crank it,the checking engine light flashes and there is a clicking under the hood around the relays on the drivers side firewall and the fan will spin then stop everytime it does this.It also makes a clickingnoise on the part just above the TPS.Today when it done this I took out the fuse for the ECM and put it back in..Then it fired up.......Any and all advice would be appreciated....
