-   82-92 V6 Tech (https://camaroforums.com/forum/82-92-v6-tech-44/)
-   -   cooling fan problem (https://camaroforums.com/forum/82-92-v6-tech-44/cooling-fan-problem-17615/)
mr porky Aug 6, 2007 03:39 PM
cooling fan problem
Help ! New to this site and just aquired a '92 RS Camaro. The cooling fan does not seem to work at all, it would appear to be an electronically controlled fan but is not triggering. Is this a common problem? Where should I be looking for sensors etc? I have a manual but it does not give any help in this area.
Would it be OK to just splice the wires and fit a switch in the dash?
Any help greatly received...
MaiNpHraMe Aug 31, 2007 01:35 PM
RE: cooling fan problem
replace your relays.
sewerrat Aug 31, 2007 11:59 PM
Disconnecting the plug going to the cooling fan and connect to 12v source and a ground to check if your fan actually works. Try to repair the system so it works as it was intended to do. That way you may not have to run a toggle switch. If all else fails then wiring adashswitch isn't to hard.
91bluers Sep 15, 2007 06:27 PM
i agree check your relays and try to get it working right then resort to a manual fan be sure to check the wiring frm the fan to be sure that its not fried or cut any where
