Camaro Overheating?
Camaro Overheating?
I got a 91 V6 Camaro RS and just recently it started running hot.
When it gets to about 220 the fan comes on then it stops a few minutes later. When you turn on the Bi Levels the fan isn’t kicking on. IDK what’s wrong but I was thinking maybe a coolant leak cause I just added coolant the other day and it was decreased by half in 3 days.
I was just wondering. Because my dad says the biggest problem I need to worry about is the possibility of a blown head gasket. I am real worried my baby is really hurting. Somebody help me out!
RE: Camaro Overheating?
well hows the engine coolant fluid in your car? did you check to see the fluid level is normal? Also if you do have a blown head gasket, the only way to find out is to do a compression test and see what it tells you.
Btw if you think you have a coolant leak, then check around the radiator to see if you see any green fluid dripping around. If you do, then you do have a coolant leak.
This site will you tell about the possible locations for a coolant leak and all you need to know to fix the problem. Good Luck Bro
http://www.aa1car.com/library/coolant_leaks.htm
220 is not hot. They run hot to burn cleaner. Loss of coolant is bad.
If you suspect a head gasket is blown causingh your loss of coolant you can remove the radiator cap and start the car and look at the coolant. If there are air bubbles coming out then that would be cylinder gasses pushing through. Or buy a block tester. It is blue liquid and a tube that you put onto the radiator neck and draw air into it. If the liquid turns green then there are cylinder gasses present.
I wouldn't say that my 91 rs has an overheating problem, but my 94 never gets up to 210. Should I worry about my 91 getting between 220 and roughly 240? It never gets into the red zone but, its just new to me :P
