89 camaro 3.4L conversion problems
I just put a 3.4L in my 89 camaro rs in place of the 2.8L. I can get the new engine to start but it idles at around 2000 rpm's and if i give it gas it cuts out. I tried the timing and it was fine. all the vacuum lines are hooked up correctly and the plugs are new. I can't figure out what the problem may be. Any suggestions?
RE: 89 camaro 3.4L conversion problems
Maybe a bad EGR??? Maybe the computer needs a little time and ignition cycles to relearn. Can you give it gas easy? How many times have you started it and how long have you let it idle?
If you can drive it try to do that. Just don't go far. My brother has a 90 with a 3.1 MPFI and he says any time he has the battery disconected he has to go through a few drive cycles before it relearns. Did you have this problem before?
