87 camaro running rich
we have a 2.8 tpi motor that runs rich and seams to run better with the maf off dont make sence to me any help.
You should have a code in your system. The fact the car runs better with the MAF unplugged is no surprising. In fact that is a common test we do. Unplugging the MAF forces the ecm into LHM. It indicates there is a sensor giving bad information.
Post back if you still need help with this. |
I'm not sure what it is because someones butchered the vac lines and I'm not sure what goes where or what sencers are there and the ones that aren't.
