1989 camaro rs v6- cold fuel injector O ring
1 Attachment(s)
Hey has anyone had a problem with a fuel leak from the cold fuel injector? I took it apart and the O-ring is cracked the part is obsolete and im having a hard time locating one
Any ideas? Attachment 9104 |
Go to a local Hydraulic/pnuematic hose shop.
Take yours with you for them to compare. Use petro jelly (Vaseline) for lube on installation. O-rings go by wire diameter - dia of the ring, amterial, generally Buna-N, ID and OD as back-up. |
More correctly referred to as a cold start "valve". It's not a fuel "injector" as we know fuel injectors.
AC Delco part # 17111954 is the 3 ring seal kit. Pick a vendor, any vendor: Cold Start Valve Seal Kit |
