clutch problems as well
ya i have a problem like that two sometimes not always it is hard to put into gear but the real problem i have is when you put it into reverse it grindes?? what do you guys think is my clutch?
its a 5speed trany. |
RE: clutch problems as well
Check the level of your trans. But it sounds like you might just have to adjust the clutch.
What type of clutch linkage, mechanical or hydraulic?
