Axle Wobble, left driver side rear
I have replaced my struts with KYB AGX's, very good shape. The Shocks have also been replaced. The rear stabilzer bar has all new bushings.
I have been driving on this setup for over a year. I recently moved to the city where there is a lot of banging on the roads. Recently there has become a good amount of wobble on my left rear side. When I hit a bump, EVEN AT 5 mph, the whole left side shakes. as if something is Loose? Any ideas? If it was a wheel bearing, wouldn't it make a noise instead of a feeling? It's like a Clunk sound possibly. ANY IDEAS what is going on? |
Jack the rear of the car up by the frame and let the rear wheels dangle. Now start tugging and pushing the wheel in and out, and front to back. Check both sides, and see if you have any worn bushings in the control arms, and torque arms, don't have any missing or broken mounting bolts, etc. Also make sure your lug nuts are tight.
I moved to a place where I cannot do that =\
also, I am looking for trailing arms with new rubber bushings. if you know a guy, send them my way. thanks again camaro69 |
| All times are GMT -5. The time now is 04:48 AM. |
